Re: Re: farmall H clutch
Posted by Don LC on April 27, 2003 at 21:38:59 from (24.166.240.210):
In Reply to: Re: farmall H clutch posted by Don LC on April 27, 2003 at 21:25:09:
Try putting it in gear ,of course start it ,now that it is moving hold the clutch in, so the springs are not applying pressure and jab the breaks to shock the disk loose from the fly wheel....I don't know how long your tractor sits.....but you might try cutting a piece of wood an putting it be hind the clutch pedal .....not much just, relieve a slight amount of spring pressure....
Post A Followup
: Re: Re: Re: farmall H clutch
