Farmall Tractors Discussion Board
Re: Re: Re: CAN'T MOW WITH A SUPER C
Posted by ltf in nc on September 14, 1999 at 18:41:50 from (206.228.213.99):
In Reply to: Re: Re: CAN'T MOW WITH A SUPER C posted by Phil on September 14, 1999 at 06:38:52:
A real spiffy over running clutch is available a 1-800-345-0169 for $35 for the 1 1/8" and for $36.50 for the 1 3/8" pto shaft. These people do not rip you off for shipping and handling. If your pto shaft does not have a groove in the side for a lock pin you will have to grind one but it is simple and takes only a few minutes with a small side grinder. I had one of the old style clutches on an old ford but I like the ease this new design has for attaching and removal. When I orded mine about two weeks ago I asked if it was in stock and I was told they had 14 on hand then.
Post a Followup
: Re: Re: Re: Re: CAN'T MOW WITH A SUPER C
