Re: Int. 826 Hydro clutch problem
Posted by Aces on April 28, 2003 at 15:32:34 from (205.187.82.117):
In Reply to: Int. 826 Hydro clutch problem posted by Centaur Nut on April 28, 2003 at 14:48:30:
First of all there is no clutch on a hydro, just a dump valve and maybe the valve which is under the deck is sticking. So with tractor in nutral and in park get down so you can see the valve and see if it moves with the foot peddel.If that is ok then could be reliev valve not seating like it should. You may have to have a flow rater put on it to determan what is wrong.
Post A Followup
: Re: Re: Int. 826 Hydro clutch problem
