The box under the gas tank is the hydraulic reservoir for the live pump and incorporates the “Liftall” valving.
The Liftall is for one-way (power lift/gravity drop) hydraulic cylinders. From your description it sounds as if your 3-point lift cylinder is set up for one-way operation by the Liftall.
The valve perched atop the clutch housing (frequently called the “Christmas tree” valve) is the optional 4-way remote valve. It is used to operate a 2-way (push/pull) hydraulic cylinders on mounted or towed equipment.
To use the 4-way valve you must first block off (either plug or valve off) the Liftall output ports. You then pull the Liftall lever back and latch it there. The system will now feed pressure to the 4-way valve.
Unfortunately you can't used both the Liftall and the remote 4-way at the same time.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
