Re: M 3-point trouble...
Posted by Ron on April 29, 2003 at 12:01:04 from (207.159.119.61):
In Reply to: M 3-point trouble... posted by John on April 28, 2003 at 18:41:07:
Is there a way to get a sway bar on it. This would be a bar with holes at both ends (to connect to the front part of the hitch and the ends of the drawbar that go through the balls on the support arms). The sway bar will have a large set screw (actually a bolt) that you can tighten down to keep the bar from expanding or contracting (the sway bar will have one bar sliding into another bar or pipe). This is how my 3-pt hitch set-up came - there's a sway bar on each side.
Post A Followup
: Re: Re: M 3-point trouble...
