Re: The harder I try the behinder I get 240U!!!!
Posted by Bob M on April 29, 2003 at 18:24:33 from (66.66.123.133):
In Reply to: The harder I try the behinder I get 240U!!!! posted by Bill Cole/Rochester NY on April 29, 2003 at 17:13:00:
Bill - Sounds like the carb throttle butterfly plate is assembled wrong on the throttle shaft - so cannot shut all the way. Suggest pull the carb off and have a look down at the throttle plate. If there is any kind of visible gap anywhere around the edge of the plate and the throttle bore when the throttle's fully closed, you've found your problem.
The other possibility is there's bad vacuum leak someplace (carb flange or manifold to block gasket).
Good luck!! ...Bob M
Post A Followup
: Re: Re: The harder I try the behinder I get 240U!!!!
