Re: What starting procedure for TD-14?
Posted by Gary-Miss on April 29, 2003 at 18:51:20 from (205.188.209.140):
In Reply to: What starting procedure for TD-14? posted by Dan Caldwell on April 29, 2003 at 18:15:31:
One of my neighbors has a UD-14 (same engine) that he pullshis sawmill with. I pulled the head last year, had the valves ground and it cranks on the 3rd quarter turn just like his dad said it did in 1940 when it was new. Now, let me see if I can remember the starting sequence. The gas carburetor has no throttle, only a choke. The lever on the left (tractor left) that goes through to the right side does at least two things. It takes the ground away from the magneto and lets it fire, it closes the extra valves in the head that opens the combustion chamber to anextra chamber, thereby lowering the compression ratiofor gas and, it turns the float loose so that gas can come into the carburetor. All of this said, you crank it on gas with the lever in one position (don't ask me which) . You watch for your diesel fuel pressure tocome up on the gauge. There should be one on the injector pump. On a warm day, just as soon as the fuel pressure comes up, open themain throttle and throw the aforementioned lever to the run position. If you need further information, E-mail me and I will go check with him and be glad to. Also, I have some manuals on the engine that I will be glad to give you info from. Let usknow how it works out.
Post A Followup
: Re: Re: What starting procedure for TD-14?
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
