Re: smta wide front to a sh
Posted by Hugh MacKay on April 30, 2003 at 02:28:48 from (216.208.58.192):
In Reply to: smta wide front to a sh posted by Dewa on April 29, 2003 at 21:48:41:
Dewa: Everything should bolt right up on putting front end on tractor. On the wheels if you don't have an exact match you can go to a store that specializes in bearings and they can sell you new bearings that will match. There is a possability you allready have an exact match.
Sometimes the stabilizer going back to the frame rails has to be modified a bit. Have also seen a few tractors that did not have the frame rails drilled for the stabilizer. Put it this way the kinks will be minor.
Post A Followup
: Re: Re: smta wide front to a sh
