Re: What starting procedure for TD-14?
Posted by Rich on April 30, 2003 at 05:09:25 from (66.82.46.87):
In Reply to: What starting procedure for TD-14? posted by Dan Caldwell on April 29, 2003 at 18:15:31:
I have a WD-9 and while I don't know if that is the exact engine as in a TD-14 I will say Gary described the same starting procedure I use on the WD-9. The gas/diesel lever on my tractor is up for gas and down for diesel but I have read that some of these International gas/diesel engines have the lever working just the opposite. Also, I usually wait one minute with a cold engine before switching to diesel even if the diesel fuel pressure is up. On my engine the fuel pressure is an indication of whether the fuel filters should be changed or not. Oh, and yes, my engine starts very easily on gas.
Post A Followup
: Re: Re: What starting procedure for TD-14?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
