Re: Re: Re: Farmall Super C wiring
Posted by Bob M on April 30, 2003 at 06:06:28 from (165.170.128.65):
In Reply to: Re: Re: Farmall Super C wiring posted by Lance on April 30, 2003 at 05:53:55:
Lance - Does your Super C have a voltage regulator (4 terminals, mounted away from the generator) or a cutout relay (2 terminals and attached to the generator)? Also does the light switch have 3 or 4 positions?
Presuming you've got a voltage regulator and 3 position light switch, problem's gotta be either a bad regulator or the system is wired up wrong. However if it's got a cutout and 4 position switch, problem could also be a bad switch or bad ground at the electrical box.
Punch below for a generator/regulator system flow chart that may be helpful...
Post A Followup
: Re: Re: Re: Re: Farmall Super C wiring
