Re: B414 IH
Posted by Fabien on April 30, 2003 at 08:19:19 from (216.209.241.134):
In Reply to: B414 IH posted by gerald on April 26, 2003 at 16:14:20:
slowly bu surely!
I&T shop manual specs for B414 gas:
firing order 1342
valve tappet gap (hot) .020 (in. &exh)
breaker contact gap .o14
distributor timing 5 degrees btdc
timing mark on crankshaft pulley
spark plug electrode gap .024
hydraulic pressure 2300-2400 psi, with 1250 pounds of weight on 3pt hitch. draft control(oustide) LEVER IS SET to the deepest (full forward ) position and speed control knob in the slow lift position.
let me know if you need more details
Fabien
Post A Followup
: Re: Re: B414 IH
