Re: Points on points please.
Posted by The Red on April 30, 2003 at 11:01:50 from (206.246.187.2):
In Reply to: Points on points please. posted by Sean in Calgary on April 30, 2003 at 10:25:19:
Sean these instructions are for a Farmall H but the 350U should be similar.
Make a mark on the base of the distributor so you know where it is for correct timing.
Loosen the hold down clamps and turn the distributor base until the tab on the points is riding at it's highest point on the lobe.
Adjust your point clearance.
Turn the distributor body back to the mark and tighten down the clamps.
Post A Followup
: Re: Re: Points on points please.
