Re: Help with troubleshooting starting a Cub Cadet 682
Posted by K.B. on April 30, 2003 at 12:45:35 from (209.163.30.28):
In Reply to: Help with troubleshooting starting a Cub Cadet 682 posted by K. Wilcox on April 29, 2003 at 19:18:58:
I'm not familiar with the 682 or any other Cub Cadets for that matter, but I'll do my best to help here. From the other posts it sounds like you have a RELAY for the starter, NOT A SOLENIOD (there is a big difference). From the positive battery terminal (assuming your mower is negative ground), you should have a cable running to one of the heavy terminals on the side of the relay. There will be another heavy terminal on the other side of the relay which has a cable running to the starter. There should be one or two small terminals coming off the top of the relay. One of these is the switch terminal, it is energized by the key switch or starter button when you start the engine and it energizes the relay to let power flow from the battery through the relay and to the starter. Check to see if there is battery voltage to the relay switch terminal (a voltmeter is great for this) when you try to start the engine. If there is, the cause of your trouble could be a bad relay, bad grounding of the relay, or a bad battery cable/connections. If you are not getting battery voltage to the relay switch terminal, the problem could be keyswitch/pushbutton, bad wiring/connections, bad battery cables/connections. Also, relays should "click" when they are energized. If you can't hear a click, start looking into the things I mentioned.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
