Re: Electronic ignition.
Posted by TomH on April 30, 2003 at 16:26:34 from (206.99.145.214):
In Reply to: Electronic ignition. posted by RedRedFarmer on April 30, 2003 at 10:29:45:
I converted to 12 volts but kept the points. Starts much easier in cold weather, but there were other things fixed at the time too (new battery cables and wires all around). Points are okay if you don't mind tweaking them occasionally; I like taking a rough running engine and hearing it purr after a tune-up.
Post A Followup
: Re: Re: Electronic ignition.
