Re: Re: Ammeter and light switch housing on '46 A gets hot.....
Posted by Bob M on May 02, 2003 at 12:39:17 from (165.170.128.65):
In Reply to: Re: Ammeter and light switch housing on '46 A gets hot..... posted by Doug in NJ on May 02, 2003 at 11:43:43:
Doug - That's definitely NOT normal! What may have happened is this: Without a battery to stabilize the electrical system, the generator will develop 15 - 20 volts or more - especially if the tractor has only a cutout relay (no voltage regulator). 20 volts across the field resistor at the light switch will cause the box to heat up pretty good.
I recommend this: Reinstall the battery then keep a close eye on the temperature of the electric box the next time you run. Or if you must operate the tractor without a battery, first disconnect both wires from the generator (or take off the gen belt) before starting.
Post A Followup
: Re: Re: Re: Ammeter and light switch housing on '46 A gets hot.....
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
