Farmall Tractors Discussion Board
Re: Farmall Cub starting problem
Posted by Fred on September 15, 1999 at 06:14:04 from (152.121.200.200):
In Reply to: Farmall Cub starting problem posted by John Schnaubelt on September 14, 1999 at 19:52:34:
I have found that in the winter time that all old tractors, dogs, cats and people like warm places. Since you have owned your Cub for 10 years, when was the last time that you replaced the points, condenser, rotor, distributor cap, plug wires and spark plugs? When was the last time the carb was cleaned or overhauled? How old is the battery? A weak battery will work OK on warm days and then quickly fail you on a cold day. To replace all of these parts is not really that expensive, but man what a difference it makes for a fast lite off.
Post a Followup
: Re: Re: Farmall Cub starting problem
