Re: Re: Re: Re: Re: Re: Re: Farmall H lift-all drive shaft I want to double check
Posted by John on May 03, 2003 at 19:36:44 from (192.233.162.107):
In Reply to: Re: Re: Re: Re: Re: Re: Farmall H lift-all drive shaft I want to double check posted by jeff in pa on May 02, 2003 at 08:26:21:
I took the housing off, (3 bolts) and used my press to press it out. Then I pressed in the new seal. the new seal was smaller (not as long) then the origional one so I put the seal where the round nut didn't have wear on the shaft part.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Farmall H lift-all drive shaft I want to double check
