Re: throttle problems farmall 200
Posted by Hugh MacKay on May 05, 2003 at 03:00:05 from (216.208.58.164):
In Reply to: throttle problems farmall 200 posted by mark on May 04, 2003 at 21:15:07:
Mark: There is no external spring your problem is all right in governor. These aren't usually to bad to fix unless you have to go into the centrifical weights. All I have ever had to do was replace spring between the two linkages, change the thrust bearing and bushings in input and out put shafts. On cost what I have done is nickel and dime stuff. I suspect the centrifical weight mechanism may be a bit harder on the pocket book.
When I say nickel and dime, it is ten years since I did this, it may not be that reasonable anymore. For about 20 years following 1975-80 parts for these old Farmalls actually declined in price. In the past 5 years or so CaseIH and other suppliers have discovered what a truly great hobby old iron really is.
Post A Followup
: Re: Re: throttle problems farmall 200
