Cub Clutch-HELP!
Posted by Kirk on May 05, 2003 at 07:04:01 from (64.252.236.33):
I split my '53 cub to replace the clutch.I bought the spring assembly already mounted to the to the plate. I also put in a new disk and throw-out bearing,essentally a whole new clutch. I put everything back together and it grinds when I press the pedal.It says in the shop manual to have 1" of free travel in the pedal. If I adjust it so that it doesn't grind when I press the pedal, then it grinds when I try to put it in gear. Any suggestions?
Post A Followup
: Re: Cub Clutch-HELP!
