Hey, Charles -- Re: Electrall thread below
Posted by Wardner on May 05, 2003 at 11:23:08 from (63.159.177.110):
There is not much you can do with the Electrall unless you have a gear box. The MTA through 660 uses a constant mesh mid-mount gear box that drives off the IPTO gear behind the main tractor clutch pressure plate. Smaller tractors used a step up gear box bolted to the Electrall. These were all driven by rear PTO. Some were two point mounted and some were trailer mounted. At the left of this page click on "Tractor Photos" and "Implement Photos" and type in "Electrall". There will be a few pictures. I have an original manual that I can scan and email to you. You should also do a search on the Farmall Forum for many posts relating to Electrall. If you are near Eastern Massachusetts, you are welcome to look at my original F400 set-up.
Post A Followup
: Re: Hey, Charles -- Re: Electrall thread below
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
