Farmall Tractors Discussion Board
Re: Farmall Cub starting problem
Posted by Bill {Antique Acres} on September 15, 1999 at 12:50:26 from (206.246.165.34):
In Reply to: Farmall Cub starting problem posted by John Schnaubelt on September 14, 1999 at 19:52:34:
I assume when you say winter you mean below freezing. I would add a bottle of Heet to the gas and see if that helps. Condensation or water in gas or carb during winter do not mix well. thus maybe the heat taking care of your problem. The other response about points and so on sounds like good advice to me. When was the last time you cleaned out your gas tank and carburetor? A less than full tank will always gather moisture. Bill {Antique Acres}
Post a Followup
: Re: Re: Farmall Cub starting problem
