Re: 460/560/??? wide front
Posted by Steve on May 06, 2003 at 04:19:36 from (64.12.97.13):
In Reply to: 460/560/??? wide front posted by Michael on May 05, 2003 at 22:22:38:
Michael,
The genuine IH wide fronts are definately better. They seem to be built a little stronger. If you aren't using a loader, the aftermarkets will work fine. I believe that a IH 450 wide front will also fit the 460-560. In the aftermarkets, the M will also fit the 460-560. The only difference is in the rear wishbone mount.
Post A Followup
: Re: Re: 460/560/??? wide front
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
