Re: 656 wide front?
Posted by RPM on May 06, 2003 at 06:02:08 from (209.152.115.185):
In Reply to: 656 wide front? posted by TL on May 05, 2003 at 19:57:00:
Any WFE from another IH bigger tractor such as 400/450/460/560/706 will fit, might have to drill holes for the rear stabilizer bracket holes to match up in lower frame rails, then check your bearing & spindle size, the threads will tell you what it came from. Coarse threads came from 400/450, fine threads 460/706. This applies to IH axles only, other brands it gets more complicated.
Post A Followup
: Re: Re: 656 wide front?
