Re: Super M: 15.5-38 to big? Fluid or no fluid?
Posted by rustyfarmall on May 06, 2003 at 11:02:29 from (216.248.75.188):
In Reply to: Super M: 15.5-38 to big? Fluid or no fluid? posted by Terry on May 06, 2003 at 10:19:58:
You definetly need more weight, but I would not go with fluid in the tires, you are right, it does eat up rims.
Also, going to the 15.5-38's will only compound your problems, unless you also add weight to that combination(if you need new tires anyway, 15.5's are the way to go)
Check some salvage yards, auctions, swap meets. etc. and get some regular rear wheel weights.
Post A Followup
: Re: Re: Super M: 15.5-38 to big? Fluid or no fluid?
