Re: Super M: 15.5-38 to big? Fluid or no fluid?
Posted by TP from Central PA on May 06, 2003 at 13:47:18 from (205.188.209.140):
In Reply to: Super M: 15.5-38 to big? Fluid or no fluid? posted by Terry on May 06, 2003 at 10:19:58:
Our 400 had 13.6 x 38's on it when we bought it. They were shot! We put some 15.5 x 38's(Firestones) on 15 inch rims. That set-up put some serious rubber on the ground. If you(or anyone) decides to run 15.5's on a 15" rim use a 16.9 tube! We made the mistake of using a 15.5 tube, our neighbor tried the same thing and his tube split, we haven't had a problem yet but I am waiting for them to split.
Post A Followup
: Re: Re: Super M: 15.5-38 to big? Fluid or no fluid?
