Re: Re: Super M: 15.5-38 to big? Fluid or no fluid?
Posted by Dr.Evil on May 06, 2003 at 14:12:21 from (12.4.181.2):
In Reply to: Re: Super M: 15.5-38 to big? Fluid or no fluid? posted by Farmall450man on May 06, 2003 at 13:28:54:
Ohhhh What Do You know about rims anyhow!?!?! ;-)
You forgot to mention that nobody makes a 14" or wider rim that will fit a stock SM rear wheel. To correctly fit a 15.5" tire You'll need rear wheels/rims from a 450 or 560 with double beveled rims. Could splice a section into the 12" rims You have but that gets expensive too. If I didn't have calcium chloride in My tires already I sure wouldn't think of putting it in a nice Super M but what do know about tires, wheels & rims anyhow?!?!?
Post A Followup
: Re: Re: Re: Super M: 15.5-38 to big? Fluid or no fluid?
