Re: SLOPPY M STEERING
Posted by Bob M on May 06, 2003 at 19:09:01 from (66.66.123.133):
In Reply to: SLOPPY M STEERING posted by TRENT on May 06, 2003 at 18:08:57:
Cause is probably a combination of things: Worn universal in the steering shaft, loose or worn on the worm gear, worn worm and gear, worn pivot shaft bushings in the upper bolser, possibly loose front wheel bearings, etc.
Recommend pull the cover off the steering and peek inside. Turn the steering shaft back and forth and look where the play is coming from (worm gear moving side to side and/or fore and aft; backlash between the worm and gear; pivot shaft moving for and aft, etc.) That'll then tell you what you need to fix.
Post A Followup
: Re: Re: SLOPPY M STEERING
