Re: 39 Farmall B serial #
Posted by LMack on March 29, 2009 at 18:00:28 from (74.190.2.103):
In Reply to: 39 Farmall B serial # posted by Frank W. on March 29, 2009 at 11:23:19:
Look on the right front of the engine block over the distributor or mag. at the very front of the block almost behind the throttle rod near the #1 plug to see the engine serial number stamped in a flat. It will not be a raised cast in number but will be stamped. For the B, the engine number was the same as the unit serial number. If the engine is original that will be your serial no.
