Re: electronic ignition
Posted by Doug in OR on May 07, 2003 at 09:06:22 from (159.121.94.198):
In Reply to: electronic ignition posted by 58 K on May 06, 2003 at 18:18:32:
Pertronics also has them. They cost a bit more than the 12 volt, negative ground systems. Before you purchase the 6 volt unit, ask yourself if you wouldn't rather convert the tractor to 12 volt, negative ground. It really isn't that costly to do this. After doing this, you can buy stock 12 volt ignition systems, which are more readily available.
Post A Followup
: Re: Re: electronic ignition
