Re: Did I screw up?!
Posted by BIG JOHN on May 07, 2003 at 09:28:55 from (205.188.209.140):
In Reply to: Did I screw up?! posted by mwkellner on May 07, 2003 at 06:42:16:
You were probably reading about the govenor on an H or M that needed the control rod lined up with the dogs on the carb.
The govenor on a C is totally different and you should be OK, unless you pulled out the govenor drive gear and didn't get it reinstalled in the right slot. If you just pulled off the housing and replaced the spring without removing the govenor drive gear then you should be good to go.
GOOD LUCK
Post A Followup
: Re: Re: Did I screw up?!
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
