Re: 10 20 connecting rods
Posted by JerePa on May 07, 2003 at 18:42:51 from (66.109.235.162):
In Reply to: 10 20 connecting rods posted by ronohio on May 07, 2003 at 13:19:18:
Only if both cranks are the same diameter. Putting a used rod on a new (original size) crank won't work unless the rod was say .040 under size so it had enough material to be rebored. You can't put a used rod on a used crank with a smaller diameter than the rod. Hope this hasen't confused you.
Post A Followup
: Re: Re: 10 20 connecting rods
