Re: Engine stuck 400
Posted by clanger on May 09, 2003 at 02:46:09 from (193.237.9.85):
In Reply to: Engine stuck 400 posted by Bernsy MN on May 08, 2003 at 19:32:35:
I got a 1962 David Brown last year that had been sitting in the open for about 5 years and was locked solid. I took the injectors (diesel) out and put a thin rod in to see if the cylinders were dry. One had about an inch of rainwater water in that had seeped in through an open exhaust valve. I sucked out the water and poured WD40 and diesel into all the cylinders and left it. After a few weeks of applying slight pressure to the crankshaft nut it moved almost a full revolution but was stopping against a ridge of crud on the cylinder wall. I then used the starter to turn it over and it blew past the ridge immediately. The engine ran sweetly after that. I sold the DB a few weeks ago as the clutch was starting to slip, and am now the happy owner of a 1979 IH484 that I'm gradually smartening up and using to finish mow 5 acres of paddock. One little suggestion if you try this method of freeing up the engine - at first try to turn the crank backwards as this way you're not trying to push against any crud that's built up on the cylinder wall. It may get things moving quicker.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
