Re: Year of H with no serial number tag
Posted by jal-SD on May 09, 2003 at 13:53:31 from (208.34.15.63):
In Reply to: Year of H with no serial number tag posted by Charlie on May 09, 2003 at 08:13:21:
There is a flat spot on the block near the #1 spark plug. If the engine block has not been replaced, the engine # should be stamped on that spot. Kinda hard to see-sometimes you have to scrape paint & grease away. Usually the engine # & serial # were the same on H's. Otherwise, casting #'s as discussed are your best bet. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Year of H with no serial number tag
