Re: How do I remove an oil pump from an A?
Posted by J MIRGON on May 09, 2003 at 17:50:48 from (66.119.33.170):
In Reply to: How do I remove an oil pump from an A? posted by Brad on May 09, 2003 at 17:05:23:
BRAD,
JUST DID MINE RECENTLY, AFTER YOU REMOVE THE TWO BOLTS ON THE OUTSIDE OF THE BLOCK IT SHOULD SLIDE OUT OF THE UPPER HOUSING, YOURS MAY JUST BE GUMMED UP A BIT. YOU MAY TRY USING A SMALL SCREWDRIVER ON THE INSIDE OF THE BLOCK IN THE OIL PUMP MOUNTING HOLE AND PRY DOWNWARD ON IT.
GOOD LUCK
Post A Followup
: Re: Re: How do I remove an oil pump from an A?
