Re: CONDENSATION OR ANTIFREEZE ?
Posted by Bob Kerr on May 11, 2003 at 09:30:43 from (64.12.97.13):
In Reply to: CONDENSATION OR ANTIFREEZE ? posted by JON MIRGON on May 07, 2003 at 16:08:46:
Sounds like you may need to retorque the head. The head gasket may not have crushed all the way to the sealing point. It is always a good idea to do that after it runs a while, and don't forget to recheck the vale setting after retorquing. I used a NOS IH gasket (steel/ asbestos)on my 10-20 and had to retorque 3 times! Copper gaskets also have to be retorqued. One other thing, did you check the head for cracks? It doesn't take much of a crack to suck water into the cyl on the intake stroke, and will also blow exhaust gas back into the coolant making it seem like it is over heating.
Post A Followup
: Re: Re: CONDENSATION OR ANTIFREEZE ?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
