Re: Timing H magento ect
Posted by gene b on May 11, 2003 at 18:22:37 from (67.200.7.250):
In Reply to: Timing H magento ect posted by Bob on May 11, 2003 at 15:06:42:
If that is the case of firing late how much do you have to turn the crank to get impulse tripping. The gear must be off a couple of teeth. If you are sure #1 is on compression and not exhaust stroke you will have to turn the gear backwards a couple of teeth until #1 is in proper position to fire at TDC.
Post A Followup
: Re: Re: Timing H magento ect
