Re: Six or twelve volt.
Posted by Randy in NE on May 12, 2003 at 05:13:30 from (216.58.237.20):
In Reply to: Six or twelve volt. posted by Fred on May 09, 2003 at 13:09:12:
Since it doesn't have a battery in look at the battery cables. The old 6 volt systems were poitive ground so the the ground would have the larger end on it. The 12 volt systems should be negative gound so the ground cable would have the smaller end on it. Not 100% way of doing it but would be a good guess.
Post A Followup
: Re: Re: Six or twelve volt.
