Re: Re: farmall super c - 8 speed?
Posted by Hugh MacKay on May 12, 2003 at 21:01:25 from (64.228.12.29):
In Reply to: Re: farmall super c - 8 speed? posted by CNKS on May 12, 2003 at 18:50:48:
Charles: the other possability is the hyda creeper drive. I have the speeds here for my 130 out of manual. 1 st gear regular 2.3 mph hydra .27 mph to a speed of 1.1 mph hydra creeper in 4th. The drawbar pull useing this hydra creeper is very low.
It is quite simply a remote valve on hydraulic system and a hydraulic motor hooked to pto shaft. You tied the clutch down and engaged pto. Basically you drove the transmission through the pto. I have never used this option. I am told they don't work very well.
I talked with a guy that had used one. He said it could have been quite a system had IH put a front mounted pump on tractor with some volume and presure and a corresponding motor on pto. He told me and this is 40 years ago they looked at possibility of finding a hydrostatic unit that would fit in clutch housing and torque tube, thus doing away with clutch completely. Purchase of another tractor became their option. They were using tractor for transplanting.
Post A Followup
: Re: Re: Re: farmall super c - 8 speed?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
