Re: Voltage Regulator Problem?
Posted by OlManRivah on May 12, 2003 at 21:42:21 from (12.91.146.50):
In Reply to: Voltage Regulator Problem? posted by jason on May 12, 2003 at 17:03:31:
Verify the Amp meter output by placing a volt-ohm-meter across battery while tractor running.
Should read about 7 volts indicating a good battery and charging.
Your problem may be a bad battery.
I would check this before messing with the regulator settings.
Post A Followup
: Re: Re: Voltage Regulator Problem?
