Re: Re: Re: removing fast hitch on IH 140
Posted by Hugh MacKay on May 13, 2003 at 15:17:25 from (216.208.58.121):
In Reply to: Re: Re: removing fast hitch on IH 140 posted by mark on May 13, 2003 at 07:47:35:
Mark: On the front end of wish bone, you remove the shaft going from wish bone to your hydraulic rockshaft. Under the platform for your feet there is a stub shaft which is the same size as the shaft you remove. You pin the wish bone up to that stub shaft under the platform. For mounting your mower at the back you remove two of the three bolts for hitch. You probably should get bolts a bit longer so they go through mower support and hitch mount and have enough thread in final drive. The lift for your mower is steel flat bar about 1/2" thick 1-1/2" wide 14" long shaped similar to a boomarang. One end has two holes that match up to holes on hydraulic rockshaft with a cutout notch for the spring between the holes. That goes on so the other end of the boomarang shape bar points downward, and to the back. On the end pointing downward there should be a 1/2" hole. A chain is used from there down to mower lift. That 1.5" square stub with rod you are suggesting, goes in the right side of cultivator mount actually goes in from the left side of cultivator mount. The rod about 3.5' long hooks to a hole on front of mower frame. READ THIS VERY CAREFULLY!!!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
