Re: HELP !! Farmall M won't stop overheating!
Posted by Michael Soldan on May 14, 2003 at 16:44:22 from (216.46.130.25):
In Reply to: HELP !! Farmall M won't stop overheating! posted by Farmall Daddy on May 14, 2003 at 14:33:52:
Farmall Daddy, do you have shutters?...once my M started overheating and I realized that someone had played with the crank and closed the shutters about two thirds. Other possibilities??? is the timing fairly well on?..I had a C Allis that would heat up like an iron rod..the timimg was way off, Using water shouldn't create a problem but coolants carry and dispurse heat better than plain water...I'm kinda stumped too as you say you had the rad cleaned and there is no thermostat...could a gasket be turned the wrong way as to block off some of the water outlets?...get a thermometer and find out what the temperature really is when you feel it has over heated..are you going by your guage? Can you see movement of fluid in the rad as the engine runs...water pump function can be checked that way..the rad cap should be on to give some pressure6-7 lbs....keep us informed..I can't think of anything else.....Mike in Exeter Ontario
Post A Followup
: Re: Re: HELP !! Farmall M won't stop overheating!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
