Farmall Tractors Discussion Board
Re: Re: Re: Need help with a dumb voltage question
Posted by Phil Auten on September 16, 1999 at 06:32:40 from (206.175.72.226):
In Reply to: Re: Re: Need help with a dumb voltage question posted by Corky on September 16, 1999 at 06:08:58:
Corky,
You really need a 12V fuel pump. If you check the local wrecking yards, you should be able to find a pump from a Japanese pickup that will work. Try early to mid '70's Toyotas, Nissans (Datsun) or Mazdas. These are external to the fuel tanks. Once the manufacturers switched to fuel injection, the pumps went inside the tanks and you can't use those outside the tank.
Post a Followup
: Re: Re: Re: Re: Need help with a dumb voltage question
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
