Re: Re: Re: 1586 shifting problems
Posted by jim on May 15, 2003 at 18:36:31 from (205.188.209.140):
In Reply to: Re: Re: 1586 shifting problems posted by scot on May 15, 2003 at 16:06:32:
The cam that Wenz has will allow the shift collar to go onto the gear futher so it will work without having to split the tractor to replace the gear that is worn. He alos has repair for the loose linakge uses split collars on shafts and replaces the roll pin with bolts.
Post A Followup
: Re: Re: Re: Re: 1586 shifting problems
