Re: 12 volt positive ground??
Posted by Hugh MacKay on May 16, 2003 at 02:32:04 from (216.208.58.142):
In Reply to: 12 volt positive ground?? posted by Adam on May 15, 2003 at 19:48:25:
Adam: Either way is just fine as long as you have it wired right for the system you use. On generator systems some regulators will only work one way. Alternator systems must always be negative ground, or at least that is what I was told by a professional rebuilder.
Post A Followup
: Re: Re: 12 volt positive ground??
