Re: Re: FARMALL CHUGGING ON ONE CYL.
Posted by Hugh MacKay on May 16, 2003 at 03:31:17 from (216.208.58.142):
In Reply to: Re: FARMALL CHUGGING ON ONE CYL. posted by DAVE S. on May 15, 2003 at 18:06:32:
Dave: I took the carb off my 140 yesterday, and my needle valve is bad allowing gas to run right through, and of course flooding the engine continously. My new screen in the sediment bowl must be catching all my rust flakes as I saw no evidence of any rust in carb. I had my suspicions about the needle valve earlier as I noticed gas smell around the oil bath breather a few times. Also when I changed oil in breather there was gas in old oil. My tractor ran well the number of times I had it going during rebuild, probably 5 hours in total. The little excursion I took it on the other night was the first time it was really out moving around at any speed, The bumps and vibration probably ended the needle valve. My reason for blaming the rust before removing carb was back a few years ago my SA was much same kind of case in that it hadn't been used for awhile. With the SA the rust went right through the screen in bowl. I suspect the SA had a break in screen, I know it broke up coming out. With 140 I put a new screen before I ever started it. So once I get parts this am, and put it back together, it should be just a matter of dumping the bowl daily for a week or two.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
