Re: Re: FARMALL C GOVERNOR
Posted by GENE B on May 16, 2003 at 04:46:01 from (205.188.209.140):
In Reply to: Re: FARMALL C GOVERNOR posted by gene b on May 15, 2003 at 19:25:16:
THANK YOU-HOW LONG IS THE SPRING SUPPOSED TO BE? I REALIZE THAT THE HEIGHT CAN BE ADJUSTED, BUT I FOUND SOME METAL IN THERE THAT LOOLS LIKE IT CAME FROM A SPRING, THE SURGE SPRING IS ONLY ABOUT 3/8". MY PROBLEM IS THAT WHEN I PUSH THE THROTTLE FORWARD THE ENGINE ACCELERATES FINE, BUT WHEN I PULL IT BACK, IT DOES NOT DE-CELERATE, I AM GOING TO CHECK ALL THE LINKAGES THIS MORNING
Post A Followup
: Re: Re: Re: FARMALL C GOVERNOR
