Re: Seized up Farmall Super W-6
Posted by Loren on May 16, 2003 at 11:30:08 from (64.65.174.118):
In Reply to: Seized up Farmall Super W-6 posted by Mitchell Pool on May 15, 2003 at 18:28:55:
Martin Seynour paints makes a metal cleaner called Iron Etch, which is a phosphoric acid solution used for metal prep. It's sold by NAPA. This stuff works every time. Take the head off the engine and pour about 1/2" of Iron Etch on top of the stuck piston, and let it sit overnight. The next day, put a block of wood on top of the piston and pound it down. You can have someone else put a bar on the flywheel ring gear to help move it. The solution will leave a slightly rough finish where it contacted the cylinder, but it can be honed out. After you get the piston moving downward, you can then use a long piece of wood to tap it up and out of the cylinder. You would want to drop the oil pan and remove the rod bearing caps to find out which pistons are stuck, as well as to find out which way the flywheel should be turned as the stuck piston is moved down. With the caps off, try tapping the pistons up using a long piece of wood. If some of them are not stuck, then you can drive them up and out. If you have two pistons stuck, disconnect the rod bearing on one of them and keep it out of the way using a rag to keep from scratching the crank. This way your not trying to move both at the same time. I used this method to remove stuck pistons in a 10-20, M, and A, and it has worked very well. My uncle has also done this with F12 and F20 engines. I just bought a W9 with a stuck motor, so I'm going to do the same thing with that.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
