Re: Adding hydralics to a B
Posted by gene b on May 17, 2003 at 02:00:09 from (65.227.11.24):
In Reply to: Adding hydralics to a B posted by DaveJ(WI) on May 16, 2003 at 20:28:37:
You can change the block to a C and then add the pump you have to extend the steerting shaft a little. You can also belt drive one over by the generator. You can also change the front crank pulley and drive one with a belt or run a shaft out the front where the crank goes. I drive a CHAR-LYNN POWER-PAC off the pto. These are very good units as they are single,two-way, pump, controls, and resivour all in a roundlittle tank about 16dia and 16 lomng with mounting bkts and 1in drive out the end pump has 1000 psi and 10gal flow. The unit will run anything you would want to use.
Post A Followup
: Re: Re: Adding hydralics to a B
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
