Re: 400 hyd pump
Posted by Red Rider on May 17, 2003 at 20:20:12 from (66.248.101.135):
In Reply to: 400 hyd pump posted by Pete Hall on May 17, 2003 at 18:07:48:
I have 5 1956 IH tractors with Tompson pumps. I have replaced 2 with new units. When these pumps start loseing pressure or leaking at either the front or rear seal they are usually shot. When these pumps wear out they start building to much enternal pressure and literally push the seals out. Mine had good lifting power but It would push the seals out.
Post A Followup
: Re: Re: 400 hyd pump
