Re: Super M TA LP
Posted by John A. on May 18, 2003 at 20:25:05 from (208.24.233.162):
In Reply to: Super M TA LP posted by J C Newton on May 18, 2003 at 19:12:05:
JC, I don't know of a pic of a SMTA-LP on the web. Guy Fays book does show some LP tractors though. That is good place to start.
I have spoken to an ol man down the road from me who has a SM-LP,it is a factory LP set-up, stage II,1954 model. The tank sets cross wise with the tractor, with the steering shaft going through the tank,NOT over it. The filler and valves faces the operator (while seated). The light brackets bolts up to the tank shroud . A 6in. piece of 1/2 pipe on the RT. & LT. side of the shroud.
Hope this helps.
Good Luck,
John A.
PS. If you have located a tractor like this get the serial # compare it to the #s in the Research & Info section.
John A.
Post A Followup
: Re: Re: Super M TA LP
